- GHOST1750ExplorerOn my second V-10. First one was in 2001 Natioinal, no problems. My second on is in a Newmar Canyon Star 3953. The motor is fine my problem is the sound. I had a 350 CAT in between in a 2003 National Tradewinds with Sparton chasses. That will spoil you. Got rid of the diesel because of maintenence expense.
- FloridaRosebudExplorer
map40 wrote:
I have a rental fleet, all V10s. Most of them over 100K. One over 300K. Some close to 200K. Never an issue.
This is a very good datapoint. Thanks!!
Al - map40ExplorerI have a rental fleet, all V10s. Most of them over 100K. One over 300K. Some close to 200K. Never an issue.
- DFordExplorerI forgot to mention the 2006 F53 chassis for class A MHs (which began production on Jan 1st, 2005) included the 3 valve heads - that's where much of the added HP came from. Ford also streamlined the exhaust system with what looks like cast iron headers.
The more gears the transmission has the better. My 2004 with the older 4 speed transmission has trouble going up long upgrades. In the higher gear, it loses speed until it drops below 50 when it downshifts even lower and then starts picking up speed. A little over 50-52 mph, it upshifts (at about 4500 rpm) and starts losing speed again. If it had more gears, it would be able to at least maintain 50 mph or better.
Ford Introduces New F-53 V8 Engine, Transmission (3/5/2019)
From what's been said here, 2016 was another major upgrade year where 6 speed transmissions became standard.
Stay tuned for the 2020 F53 chassis (which I believe is now in production) for another major upgrade. The engine switches to a bigger V8 (the V-10 is on 415 ci) and a 10 speed transmission.
Oh,iIf I could on jack up my unit and put one of those under it! I have no inclination to buy a new MH. - dodge_guyExplorer II
RedRollingRoadblock wrote:
Passes everything but a fuel station.
So 7-8mpg is bad. If I recall a DP of the same size may only get 1mpg better. So “passes everything but a gas station” is a useless statement. - RedRollingRoadbExplorerPasses everything but a fuel station.
- Big_KatunaExplorer III’ve seen several 16 models with the six speed. Look at the shifter for a D with a four next to it.
- T18skyguyExplorerI have two V10's and the maintenance is much easier than the old 460. The water pump is a simple 4 bolt unit with a big O ring just plug it in and your done. The V10's are strong runners and revvers and both of mine are rock solid. As stated above if you can afford at least a 2017 model motorhome(that would be a 2016 chassis) you get the 6 speed transmission which is also very good. As far as the spark plug issue's, just shop 2004 and later motorhomes.
- Big_KatunaExplorer IINot sure of your budget but after 2016 you get a six speed auto that basically drops cruising rpm 1000 rpm.
Class Cs don’t get the three valve.
I’ve seen delivery vans in the NE go to auction with 300-400k miles. Not as heavily loaded as a RV but still ... - AllegroDNomadWhat year? Prior to 07, V10 was 2 valve. We added Banks to get adequate power in mountains. After was 3 valve. Our current MH, 2013 36LA, does not need Banks for good power in mountains.
First MH had little floor & firewall insulation, up front. Very noisy. Current has good insulation and except for high RPMs is not overly noisy (it is not near as quiet as a rear diesel) nor is there any heat on the floorboard.
How the house and insulation is put together is important.
38,781 PostsLatest Activity: Aug 12, 2026
