I turned off breaker and waited over a minute as my phone rang so a good amount of time. Flipper breaker back on and the AC is working greater. Thank you so much for the tip and all the others who guided me in the right direction. Sure makes a difference. The center ac now turns off from reaching setpoint with hot sun beating on us. The front sensor is located on slide wall on drivers side. Original owner installed a 55 inch curve screen on an arm and it traps TV heat behind the tv where the sensor is located. Just hot enough to register 83 when TV is on so mannual operation for this one. That is not a problem. I suppose i can set at 83 and see how that works. Thanks again to all and Bullydogs1 for taking the time to share your knowlege.
