Raist11
Jun 26, 2015Explorer
Front shock replacement tips?
I've done the search but can't find anything concrete to my problem. I hate to have a second open thread but while I'm going my brakes I figured I'd replace the front shocks.
It's a 1990 Triple E Ford F53 chassis. It is going to be a serious pain in the but to get the top bolts loose. My problem is the new shocks are strapped at about 18" long. The distance between the top mount and bottom is about 21". I can't see myself being able to compress the leaf springs another 3-4" to be able to install these shocks with the strap on them.
My thought is to cut the strap, let them extend. Then mount the top hole and then use a 2x4 to pry the shock up into the bottom mount. I've gone by the part numbers listed on RockAuto and they were right on the calipers so I figure they must be the right shocks.
I've done automotive shocks before on my Jeep, that's easy. This, is an entirely different animal. Thanks in advance for any tips, hints, suggestions and even the polite point and laugh is okay.
