myface
Jan 08, 2020Explorer
Front suspention
+Hi all.New guy here. I purchase 2001 Winnebago Brave SE 29A. Runs good, but my front of vehicle is low. It have workhorse chassis. There are no airbags in front. Could it be my shock?.
myface wrote:Your MH is short probably lighter than many of us that installed the HD Henderson springs.You already ordered the air bags, they will increase your ride height. I would try them first seeing you already paid for them. You really need to know what your front axle weighs, a spring that is too stiff will put a lot more pressure on that upper A arm than it was designed to take, which is only stamped steel and over time can cause fatigue cracks in that arm. Also how are you checking how level your MH sits ?
1.25 and 58.000. I saw a springs for $360 pair with 6000lbs.
