et2's avatar
et2
Frozen bay lock
Well, I got the MH put into the new storage spot with power to keep the batteries charged. But the dang electrical bay lock is frozen. I squirted it with de-icer, heated the key and tried to open quite a few times, bought a mini pencil torch and heated the outside. The torch has a heater attachment to it for soldering. I put this behind the latch and did a good heat to the whole area. Still can't open it.
Any ideas? I know, before it's said, move about 1200 miles south :B
  • Well the only thing not tried is the hair dryer. LOL, I or my wife don't use one. So I'll get one tomorrow and give it a try. After I dig a path out of the house. About 13" of snow on the ground by morning.
  • sounds more like rust than ice.
    I've had to use this on some of my locks including the door to the coach one time!
    PB Blaster
    You should have a can of this on board at all times in an RV! Will loosen 'everything' known to man! :W
    Just went into one of my compartments and it was frozen solid, pulled out the hair dryer and in about a minute I was in. Now I've got my cooler to carry beers for the big game.....GO PATS!!!!
    -paul
  • If it's truly iced up and not something mechanical a hair dryer is your best option. Good volume of focused heat but not enough to damage the coach.
  • Can't still be frozen with all that effort.Using the right key?Lock malfunction or something.
  • Hi,
    Too late now, but packing the lock with Vaseline works in the far north. I use a radiant heater to melt the compartment doors on my unit.
  • Our lockable mailbox lock froze one year and I had to put a torch on it to get it to open. This assumes that the lock is frozen and not mechanically defective!
