- If that is the original carb I would just buy a new one and slap it on.
- Gary45ExplorerWith the electric fuel pump there has to be a return line, they develop a lot more pressure than mechanical engine mounted pump. There is a bypass valve before the carb. The constant fuel circulation prevents vapor locks. On the inside of the drivers side frame rail there should be 2 lines, on my 86 the fuel pump is there just rear of the front wheel in front of the transfer valve.
Carb fuel supply is usually less than 20 pounds, electric pumps put out close to 60, perhaps pressure relief/bypass valve has a problem or could your return line have gotten damaged, easy to check.
My understanding is electric pumps put on motorhomes because gas tank further back, also assuming your motor firing on all cylinders, spark plugs extremely difficult to change.
I had similar thing happen with carbereted motor, would not start, cranked for a long time, finally fired and exhausted vapor exploded splitting muffler. - bobndotExplorer IIITry 460Ford.com they have a lot of related info.
- Ghank1956ExplorerIt is a 460 with a 4180 carb built by Holley. I was told there were issues with vapor lock and Ford put a “fuel vapor control valve” on these units that is supposed to return fuel to the tank, I am thinking it may be the problem but can’t find any info on them. My local dealer says they are obsolete.
- Ghank1956Explorer1985 fleetwood tioga
- Grit_dogTrailblazerPossibly timing as well.
- wolfe10ExplorerPlease tell us what year your Ford 460 is.
- Gary45ExplorerFloat needle probably needs replacing
- J_R2Explorerethenol gas will destroy carbs, large or small engines.
- bobndotExplorer IIIdusty x2. might be time to rebuild the carb.
38,782 PostsLatest Activity: Sep 20, 2026
