I am not a mechanic by any means so please keep this in mind. My 98 Aerbus 460 Ford gas engine will start with starter fluid then die when it has burned. Not getting any gas. Can someone tell me whe...
Have someone turn the ignition key to the on position while you are back at the tank, with the key turned on ,you should hear the pump power up for 3 seconds. If not the pump might be bad. There is also a fuel pump relay & ford also has enercia switches on most of their vehicles that could stop the pump from getting power.
