Hi all...found an auto parts store that sold the exact hose by the inch ($1.75) Only needed 10 inches. It only needed to bend a small amount. Went and got gas and nothing leaks!! Now I just need to do the maintenance cycles to reset the codes for the smog. I reset the code for this leak but several of the maintenance cycles are showing not ready. Found a write up on how to drive to get the computer to run through the testing to reset everything back to ready before getting it smogged. Here in CA they are picky beyond reason sometimes...but it is for the planet so all is good. Thanks again for the advice.
