Jrzfly's avatar
Jrzfly
Fuel Pressure Nightmare
I bought a 1993 Ford E350/460 motor Shasta RV this year. The RV sat for a long period of time before I bought it. So first thing that I had done was have the fuel tank cleaned out and a new fuel pump and filter installed. A week after I got it back it was hard for the RV to get above 25 mph. It would bog out and back fire at the engine when you would push the gas pedal to try and excelerate. I had the cat converter looked at and it wasn't clogged. After further tests it was not getting enough fuel pressure. The mechanic drops the tank again and says the fuel pump was defective. Puts the new one in and RV drives good for half an hour and looses fuel pressure again. Take it back to the mechanic and he finds debri in fuel pump. He says the tank still has something in it. So I tell him to order a new tank, he proceeds with ordering with Ford per my VIN number and the Tank doesnt fit. So he can't find the right tank and tells me he has a better guy to clean the tank out. So back to square one. All this being said my RV has been off the road all spring and summer. Anyone have a similar problem or order a new tank before? VERY frustrated.
  • from your notes,, the first guy did not clean the tank correctly, bills on him. you have to remove tank and pump clean,, clean ..and clean. there places that can do do it, your guy is not the lace, hope it works out for you, .. have that new pump cleaned as well.and change any in line filters.
