David0725
Jan 06, 2014Explorer II
Fuel selector valve
I need a need Fuel selector valve do to mine is leaking. Mine says its a model 121 listed 919y safety valve. Max temp Ambient 170f fluid 170f 12vdc 1.0a max 312psi.the only differents is the the temp and the amps what do you think will it work? I found this one on ebay saying this I HAVE A LARGE QUANTITY OF THESE VALVES. THEY HAVE A UL INSIGNIA ON THEM. THEY ARE A NORMALLY CLOSED VALVE. THE STICKER SAYS 12 VDC 1.5 AMP MAX. 312 PSI MAX.
MODEL 121
LISTED 919Y SAFETY VALVE FOR AUTOMOTIVE USE ONLY.
FOR: LP GAS, GASOLINE AND NATURAL GAS.
MAX. TEMP AMBIENT 140* F
FLUID 77* F
1/4 PIPE INLET AND OUTLET
http://www.ebay.com/itm/FUEL-SELECTOR-VALVE-/260778128566
MODEL 121
FLUID 77* F
