MH runs good using cruise control then if I touch brake to stop,trouble I lose speed and seems to lose power, its like fuel filter is blocked . it happened today again then it run fine the rest of th...
I had this same thing happen ONCE. Came off the cruise control and hit the Jake brake and it went straight to idle and no more. Turned it off and sat awhile thinking and it started up and has been fine every since...Seems mine has no throttle cable and the module that controls the throttle is mounted back on the engine. They told me it re set when I turned it off and back on but could be caused by a brake light not going off.
