CA Traveler wrote:
tropical36 wrote:
Better question might be as to maybe having a problem like with all of them eventually and how easy is it to combat such an enormous bulk. I'd rather have 4 smaller ones and not so much to contend with for manually cranking, pushing, shoving and alignment adjustments.
Limited manual effort for my Lipper pump. Attach a drill and crank for a bad motor.
But what if the pump is the problem? Disconnect the hydraulic hoses and attempt to push the very heavy slide in? That would be very difficult. Then what? Hydraulic fluid holds the slide in (or out) and now you don't have any. As a practical matter I think if you can't move the slide with the pump repairs would have to be made on site. This would also apply to hoses and hydraulic rams.
My Lipper pump problem was a poor design that leaked fluid into the motor. Then the drill could not be used to turn the pump due to a botched design. I was able to jury rig the pump, release the valves, get the slide in and then close the valves. The second slide had not been extended. The replacement pump is a better design.
Not bashing Lipper as anything can have problems. When I pointed out the design problems (which of course they knew) they sent me a new pump. I was just a few days over the 2 year warranty. Now I have a backup pump if I want to repair it.
Just wondering how small the slide has to be, so that its pure electric like ours. I can manually release the motor brake and crank it in short order. Naturally there's always something else that could go wrong to prevent that convenience and one might have to do some repairs on sight. Neighbor has an electric lipper and the only way to release the brake, is to apply 12v power to the motor brake itself.
