Just completed a dreaded oil change on the Bounder. The Fumoto valve sure makes it easier and cleaner to drain. However, there is no way (or I haven't found it) to take that filter off without makin...
Here's the technique I used with a Cummins that had an awkwardly placed filter:
Drain crankcase hot. Let engine cool. Loosen filter with wrench just enough to break loose. Surround filter with 1 gal ziploc or garbage bag and unscrew until it drops in the bag.
