ljr869
Dec 05, 2014Explorer
Fumoto / V-10
Just completed a dreaded oil change on the Bounder. The Fumoto valve sure makes it easier and cleaner to drain. However, there is no way (or I haven't found it) to take that filter off without makin...
Dale.Traveling wrote:
I have an oversize drain pan/tube plus I cut the bottom off a gallon milk jug as an improvised funnel. Loosen up the filter and hold the improvised funnel under it as I unscrew and let it fall into the tunnel. I also use the tunnel when draining the engine.
