Just completed a dreaded oil change on the Bounder. The Fumoto valve sure makes it easier and cleaner to drain. However, there is no way (or I haven't found it) to take that filter off without makin...
I have the valve two and I got a small pan from wally world it sits on the I beam under the filter. I get it the filter lose and then put the pan under the filter and let the oil drain from the filter then when it slows down I take the filter down in to the pan when it stops dripping I put the new filter on but do not tighten it till I bring the pan down with the old filter . It works for me just be careful when bring it down .
