Just completed a dreaded oil change on the Bounder. The Fumoto valve sure makes it easier and cleaner to drain. However, there is no way (or I haven't found it) to take that filter off without makin...
Flanz, you can use it on a Harley, only cut a gal jug in half length wise and cut the bottom end out and use the bottle end to drain in pan.{ 2004 road glide}
