Just completed a dreaded oil change on the Bounder. The Fumoto valve sure makes it easier and cleaner to drain. However, there is no way (or I haven't found it) to take that filter off without makin...
I also use the fumoto valve with a plastic hose attached the tip and drain the oil into a 5 quart oil jug. I then loosen the filter and use a 1 gallon ziplock bag to remove it.
