I have add a Junior Dragster Category to the forum.
Next project, let's, move inside.
The bedroom has a ceiling fan in it. The brackets that hold the fan blades are cracking and breaking.
I called Fleetwood, and they said they did not put fans into motor homes until 2001, well that leaves me out as this is a 1997.
I could find no manufacture or model on the outside of the fan any where, so let's take it apart and see what we can find.
Look at that, there is a customer service number!
I called them up and what a present experience, they sent me the parts fro free!
So off come the fan blades.
Time to swap over the new brackets, the old ones are literally falling apart.
All Done.
So...if Fleetwood did install this fan they did a really bad job. Note how the wires are being crushed under the mounting bracket. I am truly amazed at the terrible quality of work I fine done in Motor Homes. Once again I have found that if you want it done right you have to do it yourself.
Note how the wires have been crushed. The insulation has not been compromised so I will reuse the feed line.
I'm not happy with the mount either. What was done is these bolts were feed through the ceiling, the 1/8 inch lauan, and the A/C chase, and this is what was holding the fan up.
So...time to make a backing plate to spread the stress of the hanging fan and the motion it produces, both going down the road and when it is running.
I upgraded the bolts to 1/4 inch grade 8 bolts, and will put washers on the fan bracket side, run the bolts up through the original holes in the lauan and the metal A/C chase, then through the backing plate and double nut it so the nuts do not work loose.
Now we need to move the hole for the wire so it does not come out underneath the mounting bracket.
I used a box cutter to cut the carpet on the ceiling away from the area where the hole needed to be drilled, and of course it slipped and I cut my thumb pretty good, I should have gone for stiches, but I have three buttery fly stripes holding the cut together.
As the wire is going through the metal A/C chase a gourmet is needed.
So now the wire is protected from the sharp metal edge of the A/C chase and has been moved out from under the mounting bracket, the way it should have been done in the first place.
Now the mounting bracket is back up in place and I could probably hang from it. The wire is in the clear.
The fan motor is hung off the bracket and new wire nuts were used to connect the wires, who ever did the original install did not strip enough insulation of the wires and the original wire nuts were tightened on the insulation, not the wire.
The outside housing is put back up.
The fan blades are attached and the fan is tested, all works as it should again.
