jerry8mm
Mar 11, 2014Explorer
Fuse location for lights
I have a 2002 National Sea Breeze (Ford chassis). I am hooking up a dolly to tow a Prius. I was checking out the connector and everything worked -- except in the process I shorted the running light pin to the ground pin. I saw sparks. Now I don't get any power on that pin. Obviously I blew a fuse, but where do I find this fuse?
There are some fuses in a panel beside the driver's seat and some outside in the basement compartment next to the inverter.
Is there an in-line fuse or is the blown fuse in one of these panels? I guess I could pull every fuse out of each panel and look at it, but they don't come out easy and I'm not sure the fuse I'm looking for is even in one of these panels.
Any ideas would be helpful.
Jerry
Jerry
