Stutch's avatar
Stutch
Garmin Basecamp
Hi all!
I'm trying to use Garmin basecamp. I honestly have to say I have never seen a application this poorly designed in my life. Intuitive, it is NOT!
A simple example.... There is a function on the menu bar labeled "Trip Planner." Nowhere in Help or instructions explain what this is or how to use it. If you search the index or subjects it comes up blank.
I spent most of the day trying to put in a round trip route with 5 stops and have failed. Basically very frustrated since I was hoping I could use this to plan and then export to the RV760LMT.
Have you had better success with Basecamp or can recommend any other software that will export to a Garmin GPS?
Thanks
  • I agree it's not very user friendly. I use the new route function and drag waypoints into it. You obviously must set the waypoints first. Then you can add additional waypoints to the route. I plan my entire trip then transfer waypoints to the GPS. I just use GO TO function on my GPS each day not the route function. Now I've used it for a while I like it but takes lots of patience to learn.
  • I recently updated the maps on my Garmin Nuvi and wanted to try the trip planner in basecamp. You're fight, intuitive it is not! What's worse is, after playing with it and figuring it out, I discovered my Garmin is too old to use it on! Ack!
  • I just bought a Garmin RV 760, it and basecamp have to be the worst designed GPS I ever laid my hands on. Of course I'm 72 years old and nothing comes easy these days. I don't have the time to find a replacement right now, but soon as I get home someone can have it for cheap on Ebay and I'll find something more user friendly.
