dennygene's avatar
dennygene
Gas pump keeps clicking off and slowly fills gas tank
I need some advice on what to look for in my 1997 Fleetwood Flair just recently when I get gas the pump keeps kicking off and I have to put fuel in very slowly. I have taken the Vapor Canister off and still no change. Vents are open and no kinks in the lines.
Thanks Dennis
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    This is a very common problem... as the poster above said look at the filler tube. No look (if you can) at the one on your car.. I can't do a decent job of ASCII Drawing but
    car
    . Tank
    Motor home
    ----_______ tANK
    Much longer tube and not much "slope" the result is if you have a lock on pump even the 1st stop may be too fast.
    A piece of wood like quarter inch. Cut in stair steps.. You may find a position that works.
    ALso if you can tilt the RV away from the pump
    And if you have dual fill (Drivers and passenger side) open both gas caps (don't forget to replace both)
  • Check the RUBBER hose from your filler port to the steel fuel tank for kinks or interior deterioration. They do go bad and especially after 20 years.
