- FloridaRosebudExplorer
Solo wrote:
As has already been covered, I concur about driving experiences. One of the big differences for us other than the diesel vs. gas discussion so far is that our DP has residential quality plumbing, heating and fixtures as many do when looking in the upper range of a manufactures line. Aqua Hot, residential appliances, non-gravity-flushing toilets, residential sinks/fixtures, etc. We live in our motorcoach and so the driving and living are equally important. For us, the driving experience is just one part of the differences. Is a DP better? Depends upon your needs/wants. It costs to play.
Well put....this is the important part..."Depends upon your needs/wants. It costs to play". I like that...:B - SoloExplorerAs has already been covered, I concur about driving experiences. One of the big differences for us other than the diesel vs. gas discussion so far is that our DP has residential quality plumbing, heating and fixtures as many do when looking in the upper range of a manufactures line. Aqua Hot, residential appliances, non-gravity-flushing toilets, residential sinks/fixtures, etc. We live in our motorcoach and so the driving and living are equally important. For us, the driving experience is just one part of the differences. Is a DP better? Depends upon your needs/wants. It costs to play.
- wvabeerExplorerIs it true that diesel is a cushier ride than gassers? yes I have had 3 gas motor homes, 1 with air suspension. And does it get better gas mileage? Yes, it doesn't burn a drop of gas. HA HA ok fuel mileage is simliar. I've gotten from 5 to 9 mpg with gas, fuel 7 to 9. Does it climb hills better and do better going downhill as well? Mine is a 300 Cummins ,it handles mountains much better the any of the gas. Downhill is different the diesel has an engine brake so you shouldn't heat up you're brakes. Gas will get hot brakes if you aren't careful.
- Big_KatunaExplorer IISomeone said gas go up hills faster. Not true.
What determines how fast you go up hills is power to weight ratio. - Dutch_12078Explorer III
2gypsies wrote:
huntdooly wrote:
Dutch_12078 wrote:
Since we spend ~95% of our time living in our Class A rather than driving it, the floor plan and "livability" are more important to us than the power, ride, and handling in selecting a coach. We did own a DP for a short time, but the floor plan just wasn't a good fit for us and the softer ride, etc., weren't enough to make up for that. Two gassers later and we're still happy with our choices. Now we're in our mid-70's, and likely won't be making another change before we hang up the keys.
Great points to keep in mind!
I can never understand this comment about a floorplan being better than quality. What good is a floorplan if things around it fall apart? Choose a quality manufacturer and then choose one of the floorplans they offer.
Where did I say the floor plan is "better" than quality? Ride and handling to not indicate "quality". We haven't had anything "fall apart" in our coach yet, although I have had to restring a couple of day/night shades lately. The same type of shades used in many DP's... - Executive45Explorer III
rr2254545 wrote:
Trackrig wrote:
As a DP owner, IMHO:/Snip?
3. When running the generator in very hot weather for the A/C at night, the A/C is in the front and the main bedroom is in the rear - quieter.
Bill
3 Not true My diesel has two a/c one front and back no difference between the gas and diesel - bigger boys have 3 airs and still not true
/snip/
I believe he meant the GENERATOR is in the front and the main bedroom is in the rear - quieter. Location of the A/C is irrelevant. The GENSET located up front makes for quieter sleeping at night while it's running.....Dennis - 2gypsies1Explorer III
I can never understand this comment about a floorplan being better than quality. What good is a floorplan if things around it fall apart? Choose a quality manufacturer and then choose one of the floorplans they offer. - huntdoolyExplorer II
Great points to keep in mind! - huntdoolyExplorer IIThanks so much, everyone!! Such good info here!! We started out looking at gassers, but then are pondering moving toward DPs now.
- flyboykuaoExplorerThe posts above cover what I was going to say - I am very pleased that I picked a diesel pusher. For me the drive itself is half of the fun. The smooth ride, lack of noise, and lack of vibration make it feel like it is gliding over the road. Noise and vibration can impact my energy level over time. With the air suspension I am sitting high.
It was comments on sites like this that swayed my opinion - and I am grateful.
38,769 PostsLatest Activity: Mar 31, 2026
