VA-Apraisr wrote:
I had this exact same thing happen and all it was , was the ground wire was corroded. Simply scraping it clean and reattached it and generator ran like normal. Just a thought…….
If the ground connection from the generator to the RV chassis frame was high resistance due to corrosion or rust, your generator would not start or would at least turn over very slowly. Once the generator is running, the chassis ground connection is no longer required for the generator to keep running once started.
