gbopp wrote:
I thought the OP was concerned about fumes falling into the window. I didn't realize the concern was the heat from the Gen-Turi damaging the window. :E
Genturi pipes are NOT hot. That's the whole reason for buying them!
Posted By-jillhop I have purchased a Gen-Turi (many of the dog events I plan on attending require them) and unless I have an extensive rerouting of the generator exhaust pipe, the Gen-Turi stack will route over a large window. Is this a safe configuration? I'm not particularly concerned about the cosmetic issue of the pipe running up past the window.
Mine runs up the side of my window also. No problem the exhaust is well over the top of the MH. Have never smelled exhaust even on the most windy day.
What you DO have to watch for is if it runs up parallel to your AC unit then you have to reroute it. Which is nothing more than an additional pipe. This is show in the directions that come with it.
Welcome to the forum! :C
I show dogs also. I just wish ALL dog shows that don't have hookups would require exhaust stacks.:W
