clayhubler
Jun 11, 2017Explorer
"What sort of RV are you in?"
1994 Safari Sahara 34'
"Try to start the generator while holding your dash "BOOST" switch so that you are using both your house and chassis batteries. If this works than you have a problem with one set of batteries. Either they are bad or the connections are bad."
Still same thing.
So I have now disconnected and cleaned all connections, the battery cables and the wires from the solenoid to starter. All are clean, and all show 12.8 volts, so solenoid is working, voltage is getting to the starter, but starter isn't doing anything.
I'm thinking starter is bad?
Still same thing.
38,782 PostsLatest Activity: Aug 23, 2026
