dlt123me's avatar
dlt123me
Generator doesn't supply power to air, microwave, in cabin
Hello, I have an interesting problem. I have a 1995 Class C Jamboree Rallye which has a 4K Onan generator. The generator runs fine, but it doesn't supply power to the cabin inside the MH. It should run the air conditioner, microwave and refrigerator but it doesn't.
When I plug into land power, all works fine. Any ideas what is happening here? Is there some fuse I am not aware of or is there a connection from the generator to the cabin that may have come loose? Is there a switch on the power converter, wherever that is, that needs to be tripped or re-tripped?
How do I trouble-shoot this?
Any help is appreciated... and thank you.
Dennis
  • Also check to see if there is a socket (plug) in or near the generator compartment where you can plug the motor home 110V cord into, not all generators are hard wired into the motor home.
