tropical36 wrote:
sailor_lou wrote:
If you can wait to perform the repair, I would remove it and bring the stator and rotor to a motor rewind shop. Usually they can be repaired or rewound for a fraction of the cost of a new one or even new parts. I had an Onan rotor repaired for $40 after an incident with mice and the replacement was around $900 online. Maybe use a portable generator in the meantime. Good luck.
Lou
05 Travel Supreme Envoy
Motor rewind shop is what I had in mind also, if indeed where the problem lies.
If not cost effective, though, I keep wondering if someone might have installed as large as a 4kw gen set in this small of a space and will check it out, once I see a camping world. In fact I remember a long tread dealing with Chinese gen sets, but can't find it now.
Meanwhile, we're heading north for now, so maybe better with the heat and considering that we don't travel more than 100 - 200 miles a day.
Thanks to each and everyone for the feedback so far.
I am in the same boat you are, I spent a month out west dry camping and my governor on the Genset went out so I couldn't use it. It was cool enough at the higher elevations. But if and when the repair becomes too high I was thinking the same way. The main thing that it gets used for is the micro wave. Only once for AC in 10 years. I spend more time exercising it than it gets used. But I think a 2 or 3k watt replacement would be fine. I will be watching this thread for other opinions.
