Roman_Duck
Mar 04, 2014Explorer
B&B Travlers wrote:
The Cat diesel generator is on a power slide in and out. Sorry for not stating that earlier. It is manually controlled by the power toggle switch in the fuse compartment on the side of the coach.
Ok, now that there's a better understanding of your system, it could be a number of things; check the fluid level in the resoviour, also could be a defective solenoid on the pump. or a control valve; they have check valves that could be sticky from non use. After checking your fluid adding if needed, try exercising the hydralics whith your toggle switch.
One other thing when checking the fluid level, look for any wet spots, or oil residue on the piston of the ram.
We have had simlar systems on our equipment and usally it's one of the above. Good luck, keep us posted
38,707 PostsLatest Activity: Feb 28, 2025
