two_travelers's avatar
Nov 24, 2017
Generator start issue
Went to turn on generator, Onan 4KW, today to run it for a while. Primed it several times then hit start. The first crank of starter motor sounded like a dead/low battery then it sounded normal. Same thing happened several times since it did not start on first try. What battery is the generator hooked to? Both house and chassis showing good charge voltage (14+V). With no AC battery voltage was about 13V. After running generator for an hour I turned it off waited a few minutes then hit start again. No problem this time. Any ideas??
  • Sounds to me like a high resistance (corroded) connection on the genny starter motor.
  • Two,
    We have seen this a lot over the years.
    It will turn out to be either a bad battery that recovered after being charged.
    Or, it is a bad connection in the starter power circuit. This one is easy a cheap to fix if you do the complete diagnostic.
    Matt
    maybe got a battery going bad seen where voltage with no load reads ok but under load(trying to start gen set) it(battery volts)drops dramatically
