GKU wrote:
Thank you all very much for the help. I have tried all you suggestions.
Started the coach and tried to start the genset..no luck
Held down the starter switch for at least a count to 20-30..no luck
All 4 house batteries test OK as well as the Chassis batteries
Check voltage at the genset..nl luck
I short I have tried everything, I have an appointment in 2 weeks I will get back to everyone as to what the problem was.
Thank you all for your help
The solenoid on the genset could be bad, I guess and would take a voltage reading there and on both main terminals, when trying to crank it. Whatever you find, do keep in touch, as you say.
