GKU's avatar
GKU
Generator won't Start
Just purchased this DP new a couple of months ago and I have a lot to learn. When I try and start the generator you hear "Click-Click-Click" sounds like the battery is dead. This is where my problem is, I can't find the generator battery. It is not in the front where the generator is. I have two battery's in the rear that I think are for the engine and 4 house battery's. The generator did work about 3-weeks ago-started right up.
I have a 2014 Tiffin RED 340-Cummings, 8k generator.
Can someone point this new DP driver in the right direction?
  • I have a diesel gen. and when you hit the switch it does the same, tick just hold it after about a half minute then it will start. Like when you crank the main engine it wont crank until the light gose out
  • It sounds like your house batteries are discharged. If possible, start your coach and let it run for a few minutes then try to start the generator. Or plug in shore power for a while and charge your batteries.
  • You must have a warranty for this? If so, bring it back to them and have them fix it. If possible, watch them.
    Also, did you not go thru a walk thru of the coach before you picked it up? Since this is a new MH you must have manuals that WILL explain the functions and location of all components within the coach. You should read this.
    -paul
  • The 2 batteries in the rear are called the Chassis. The other 4 (Qty 4 of 6 volt) coach / house.
    It is common for the generator to be connected to the house batteries.
    1) look for the AUX start switch, this connects the chassis to house.
    2) get a volt meter and measure the battery voltage across the house.
    Black on a good common ground (frame, rail). The measure to the (+) side of the battery.
    I suspect your coach has a Inverter/Charger installed. When connected to shore power or generator on. The Charger is operating.
    Also since this is a new coach, the dealer should have done a walk thru. Also a stack of documents should be on board.
    Make sure you read thru them all. Locate the items they are talking about.
  • It would be unusual for the generator to have a battery separate from the house (or engine).
    Definitely sounds like the solenoid is engaging the starter but not enough juice to start.
    Are your house batteries okay?
