dougrainer
Apr 06, 2019Nomad
Look at the Genset remote harness quick connect AT the Genset. Gensets use a GROUND circuit to start and stop. If the pin for the start circuit at the quick connect is corroded(usually is) inside the quick connect the remote switches will not work to start but will to stop. OR the splice connections at the remote harness at the genset the start wire is corroded or broken off. Doug
38,769 PostsLatest Activity: Apr 24, 2002
