Gjac's avatar
Gjac
Explorer III
Apr 06, 2019
genset will not start from remote switches
I have a Kohler 5ckm21 genset it will start from the switch on the genset itself but not from the switch above the stove or the dash board. When the genset is running the light come on the switch on the dash and both switches will shut off the generator, but neither switch will start the generator. Any ideas of what is happening here?
  • Gjac's avatar
    Gjac
    Explorer III
    ksg5000 wrote:
    If it's like my Onan you might check/clean the connections to the board on the generator.
    That is the first think I did, but it did not help. The thing that is confusing is both switches work to shut the genset down but only the one on the genset itself works to start and stop.
  • If it's like my Onan you might check/clean the connections to the board on the generator.
  • Gjac's avatar
    Gjac
    Explorer III
    MountainAir05 wrote:
    Do you mean it will not turn over from the other two switches or it will not run.
    It will not turn over.
  • Offhand, it sounds like a loose or broken wire somewhere in the connection between the switches and the generator. I would check the control connectors at the generator first if they're reasonably accessible.
  • Do you mean it will not turn over from the other two switches or it will not run.
