valhalla360
Jul 22, 2015Navigator
All else the same, it's a toss up (or an ego boost). The modern gas engine will likely be running strong when the rest of the rig is trash with just normal maintenance. Likewise, if you don't do maintenance and abuse the diesel, it might not last 5yrs.
Unless you are running the carney circuit (40-50k miles per year), the fuel economy will likely never cover the higher up front cost of a diesel.
All else not the same and it's more about your needs and you get the engine that comes with it. Ie: If you want one of the big high end pushers, they only come in diesel.
38,763 PostsLatest Activity: Dec 26, 2025
