2cAmerica's avatar
2cAmerica
Given choice gas or diesel powered fill time coach
Which and why if given choice gas or diesel powered (36 - 40 foot) coach with 2500 - 3500 lbs toad attached for fill time usage?
Thank-you
  • The fuel cost per mile is less with diesel as it gets better mileage
    With the gasser based on todays price here in Minnesota 39 cents per mile based on 7 mile per gallon
    The diesel pusher is 32 cents per mile based on 9 miles per gallon
    Since the mileage is 22% better the diesel is more cost effective unless the price per gallon exceeds gas by more than 22%
  • Dutch_12078 wrote:
    Buy the floorplan and features you like best regardless of how the coach is powered. You'll be spending a lot more time living in it than you will driving it.
    Don't take this the wrong way but it's apparent you've never owned a diesel.
    While a gas coach is wonderful, I cannot think of even one advantage it has over a diesel.
    Even when not driving, typically the build materials are a touch above a gasser - not a knock on a gasser, there is just more chassis under the diesel to handle the weight so they can use heavier materials.
    Also the basement storage of a diesel is something a gasser just can't do. And full timing storage is always at a premium.
    Now get to the driving side of the discussion.
    Years ago we were warned by friends DO NOT DRIVE A DIESEL PUSHER UNTIL YOU ARE READY TO SIGN THE PAPERS. They were right.
  • Full time where you plan to move often, diesel.
    Full time where you only move 3-4 times per year it would make no difference at all. Buy the best floor plan for your lifestyle. You will get WAY more coach for the money with gas at the disadvantage of ride, comfort and quite.
  • We will never full-time but you just can't beat a diesel for power and CCC (especially with a tag axle).
    And, it all depends on your budget. If your budget puts you into a 20 yr. old diesel motorhome, you might be nickeled and dime'd replacing things that have worn out (house items).
    Good luck and safe travels,
    MM.
  • Buy the floorplan and features you like best regardless of how the coach is powered. You'll be spending a lot more time living in it than you will driving it.
  • I would buy what suits my needs. When you get above 36' the gasser drive shaft is pretty long. I like my gasser @ 34' and it has all I need. If you need to tow more or go fast up Mtn grades you need to look at those needs. Doubt you will wear out either gasser or diesel engine. Most old MHs still have very low mioeage.
  • Assume you mean full time use? After having a gas coach first and now a diesel, I prefer diesel because:
    1 - we can fill up where the trucks do. Sometimes it was difficult finding a place to get in and out of with a gas coach with a car in tow. This is especially true on the eastern half of the US so might not be a problem for you.
    2 - the gas coach was significantly more difficult to keep cool when driving in the heat because of the engine located up front between the driver and passenger.
    3 - it is easier to carry on a conversation in the diesel coach vs the gas coach again because of the location of the engine.
    4 - easier to sleep overnight if you have to run the generator while boondocking for the AC because the generator is located away from the bedroom area.
    5 - carrying capacity of the diesel is better not just because of the weight but also because the weight of the front axle on a gas coach is upfront which limits the weight available in the pass through storage bays. Locating the engine in the rear of the coach on the larger capacity axle leaves more capacity left for "stuff".
    6. The exhaust brake. I never minded it taking longer to get UP the big hills/mountains with the gas coach but sometimes I was a little nervous going back DOWN the hills/mountains.
  • I diesel MH can pull up to 10,000 pounds so no need to have a smallish car
    I have owned both and far prefer the diesel -
    Much better ride - steers better too
    Quiet - I can actually talk to my wife
    Much much more room to store stuff
