MSHappyCampers
Oct 01, 2012Explorer
mikebo wrote:
I use LEDs for a lot of lighting tasks on my model trains and have found that using higher resistances in the dropping resistors will usually lead to much longer life with minimal reduction in light output. In this case, I would try using two of the 270 ohm resistors in series and see if the brightness is good.
Mike
Mike, when I was experimenting with the resistance I tried a 330 ohm resistor and the LED did not light at all. What do you think happened there?
