Loren_Ross
Mar 21, 2014Explorer
Grey Tank Valve Stuck Closed
Need some help guys... Left my grey dump valve open, which I usually do until the black tank gets almost full.. Just checked the panel and discovered that the black is almost full and the grey is already full. OK, thought my ADD was kicking in so I went out to drain some grey water and discovered the I had, in fact, opened the valve. Unfortunately, it appears that it is stuck in the closed position and the handle is no longer attached. Looks open, but isn't.
I've searched the forum for hints, but found nothing helpful. I know I can't be the first guy this has happened to... I'm handy and can do most anything, what do I need to do????
