- The_LogansExplorerWe found.the slide awnings to be a double edged sword. They kept the slide top clean, but we had a slide awning ripped up in a storm. So we had to bring the slides in during a storm. That was a pain, so we haven't gotten them on the last two campers. For us it's easier to just hose off, or sweep off the top of the slide.
- magnusfideExplorer III
TXiceman wrote:
If a manufacture designs and builds a slide system properly, it should not leak and require a slide topper. The topper will help in keeping the top of the slide leaf free, but they can also be a major pain in the wind.
Ken
Not sure where you get your info but long-term data on customer feedback shows that ALL slides will leak in a driving sideways rain. The debris also causes pooling and in turn the water will enter a coach. Get one with a thorough weather strip (no daylight peaking through) and a slide cover for the top. - TXicemanExplorer IIIf a manufacture designs and builds a slide system properly, it should not leak and require a slide topper. The topper will help in keeping the top of the slide leaf free, but they can also be a major pain in the wind.
Ken - RambleOnNWExplorer IIA lot of RVs with slideouts do not come from the factory with slideout awnings. We had the 2 awnings added to ours. We have the type of bracket that extends beyond the slideout:
Here are some other examples from PplMotorhomes. - tom311Explorerhow come when I see the grey and redhawks theres is no awning over slides?this is a new experience for us when we buy a motorhome later in year.just want to have a good set up with no problems.
- RambleOnNWExplorer IIWe have 2 slideouts, both with slide awnings. There have been no leaks even in the most torrential of downpours. Our awnings extend 5" beyond the slide seal on both sides.
I clean off any debris that falls on the awning before retracting the slide so debris does not get wrapped up in the awning. A lot drops off just popping the underside of the slide awning. - tom311Explorerthanks for all the input.with us it would be used maybe 6 weeks a year and kept inside our building.the grey and redhawk fiberglas roofs?i like the 29 redhawk the best as the floor plan goes.i see the one I saw online had auto level too. I think with my shoulders being bad this would be just a little bit better to have.
- MSGMadhatterExplorerSldeouts make rving much better. My 2003 Greyhawk never has leaked.
Sweep or blow them off, lubricate them and you should be a happy camper.
We have had 2 34ft Jayco TTs , a 2006 & a 2012, neither ever leaked.
Still kept the Greyhawk, much easier to travel in. - NC_RoamerExplorer
tom311 wrote:
n c roamer,when you say it leaked in hard rain doesn't that damage the finish and or cause a mold issue?and logan I am in ohio so Indiana would be good idea.just wondering if no slide is better,,but would like to feel comfortable with no issues.
The leak was along the vertical rear gasket where the slide closes against the motorhome wall. The small amount of water, maybe 2 fluid ounces, ran down the outside of the rear slide wall which is not wood. It puddled on the vinyl flooring where it was wiped up easily without any damage. The leak never got onto any wood or carpet or behind any wall where it could not be blotted up. If it had to leak, it was not a bad place. - The_LogansExplorerTom, for sure go visit the factory... it's about a seven hour ride for us from WV, but well worth it. This is our second Jayco, and we like to have warranty service done at the factory. The are A LOT FASTER than a dealership, and have the equipment, experts and parts to handle whatever they find. Then when they work on the unit, we go and have a good time... we always make a mini vacation out of the trip.
The slides seldom cause problems, and when there is an issue, it usually just an adjustment. They add so much living space inside, they're well worth it!
38,780 PostsLatest Activity: Nov 22, 2015
