Capt_Steve's avatar
Capt_Steve
headlight switch on 1978
Problem- gauge lights quit working, 1978 Dodge Class C. Has anyone replaced their headlight switch? I need to know which parts of the dash to remove to reach the switch. I have removed the panel under the steering column. Should I post this in a different section?
  • most of thouse switches you pull the knob out as far as you can, and there is a button on the back you push and the knob will pull all the way out, then just have to undo the nut on front of the dash and the switch comes out..
