RZRguy's avatar
RZRguy
Dash Headlight Switch
I have a "99 Southwind 32V with Ford V-10, problem is the Headlight switch came apart and fell out. Does anyone know how the headlight switch attachs to the dash? Thx
  • This is an interesting post. Ford does supply the dash and light system, but, there's apparently several different changes to the seemingly same parts. Is the switches still work correctly, I believe I would just bolt it back in as others have done.
  • RZRguy wrote:
    how do you unplug light switch plugs?
    Pull the tab on the back and pull the plug off.
  • There is a metal plate behind the dash and basically it just sandwiches the dash between the switch and the plate. Mine broke like the one in the link, I ordered another and broke the new one again while installing it.
    So I then drilled 2 holes at 3 and 9 o'clock through the face and backing plates and screwed it all together.
