Old-Biscuit
Apr 14, 2014Explorer III
Under the second cover (after you remove shroud) where evap coil/heat pump is a drip pan with drain holes.
Sounds like your units have drain tubes that run thru roof.
The drip holes and or tubing is plugged. Just need to clean them out.
Might need to flush out with a nozzle on garden hose stuck into drain tube
Access to drip pan drain holes may require movement of evap coil etc.
My drip pan drains onto roof vs drain tubing.
I had to gently pull evap coil sideways to access the drain holes....which are very small.
I enlarged them will a drill bit.
38,774 PostsLatest Activity: Apr 26, 2026
