dianna119's avatar
dianna119
Heater Fan wont cycle off
We've been working well for a while but now have a new issue. We replaced the Thermostat a few years ago and all was well. Last winter (1 year ago) I had an issue when the propane heat was on occasionally the fan (set to auto) would try to cycle off when set temp was reached in coach. It actually tries to go off and pops right back on. In summer the basement AC worked fine and the fan cycled off properly. Now here we are in winter again and the fan when set to heat tries to cycle off and jumps back on. I ended up turning it completely off and after turning on/off 3-5 times finally the fan stayed off. I plugged in an electric heater but waking up to 40 degrees inside the rv wasn't fun. Ideas? What is confusing is the fan cycles properly when in AC mode. Can it be the thermostat or something else? Thanks for your input and Merry Christmas.
  • Just a thought.....has it been raining? Have you washed the RV recently? The reason I am asking is that our furnace fan would come on without it even being set/turned on after a heavy rain. We have the Atwood furnace that works with the front a/c thermostat. Anyway, after removing the outside facia, I put some peel em stick em 1/4 inch foam insulation (roll type) over the indents on the foam gasket and no more problem. May be really off base, but just wanted to share, in case a possible 'fix'.
  • dougrainer wrote:
    YC 1 wrote:
    I am betting low voltage at the fan is causing the vane switch to not allow the ignition sequence to start.
    Time to check the voltage with the fan running right at the heater wires.
    Of course a quick battery check would be in order to start.
    The OP is NOT having a Lighting problem. They are having a fan NOT shutting OFF after a Heating cycle is complete. Doug
    ". I can hear the furnace burner shutting down and fan stays on."
    If the voltage recovers enough for it to light and come up to temp the voltage could be pulled down enough for the fan to slow and not allow the furnace to light again. I have seen this happen and you end up with a dead battery and cold rv.
    Low voltage is easy enough to check for.
    While this is true, the OP would be DEAD overnight and would complain of no lighting or other 12 volt problems. Doug
