ssands's avatar
ssands
Heating basement in the winter
We have a 2014 Tiffin Allegro RED and are planning to spend some of the winter in Pigeon Forge Tn. I'm looking for suggestions on propane usage while there. There aren't any propane people that will come to your coach. Renting a larger bottle from them requires a 3 year contract. The CG says that everyone breaks down and drives to the propane supplier. I'm trying to avoid that hassle. One option is to buy a 30 or 40 LB bottle and tie it in. There's not enough room to install an "Extend-a-stay". We can use electric inside the coach but I worry about keeping the basement warm enough to keep the pipes from freezing.
  • Cheap Heat has some very specific requirements and high amperage requirements. You need 50 amp service at a minimum and some special wiring is required.
    If you use electric heat inside, you can also use electric heat outside. We use a couple of 100W light bulbs in the wet bay and where any plumbing exists. There are also some really nice, really small 250W electric heaters that will do the job and circulate the air as well. If you plan on "seriously cold" camping you might need the propane and the electric heat to keep your plumbing safe but in most 20's - 30's camping, most class A's will do just find with a bit of supplemental heat.
  • If I had room I would install Cheap Heat which is basically an electric heating add-on which uses your duct work.
  • Just came back from the West. The winter-overers use that extra cylinder outside with an isolating valve and regulator to the main utility line. Just make sure your connections are outside any compartment and has fresh air.
    Newer units direct heated air through ducting. Ne-e-e-ver use heat tape=majority of fires (hillbilly Ahia chronicles)
  • DrewE's avatar
    DrewE
    Explorer III
    It looks like the average daily lows are not much below freezing and the average daily highs are well above freezing year round in Pigeon Forge. Much of the time you probably would not need to do anything to prevent freezing of tanks in enclosed basement compartments, doubly so if the RV is generally heated in some fashion or another. I suspect (but do not know) that the pipes are all inside the insulated portion of the RV, rather than being outside or in the basement area; that's generally the case for RVs that are set up to be usable in freezing weather.
    According to the specs I see online, a 2014 Tiffen Allegro Red 38 QRA has a 24 gallon propane tank, or around 80 pounds usable capacity.
  • You can use light bulbs, If you can find the short oil fil heater that also works. If you have a taller bin then the regular size will work. Our 99 had a switch that you turned on to heat the basement. It was just a blower motor like use on boats to suck warm air from the duct and blow thru the basement area.
