Usually a furnace seperate from the AC but same thermostat. Have to make sure the switch is on "heat" and that the thermostat is set higher that actual room temp. The fan runs a half minute or so before the furnace burner kicks on. Or, of course the furnace simply may be malfunctioning, not igniting the burner.
