retiredhfd's avatar
retiredhfd
Help -slides will not extend
I have 2 slides on my 2003 38' Fleetwood Excursion that will not slide out. Is ther a reset button somewhere - I don't have a manual for the slides? Motor is on in park I am in Neutral and stabilizers are down - coach is level. Any suggestions would be appreciated.
Thanks
  • All compartment doors are shut good and I have already tried in and out of gear- parking brake on and off several times - no luck. I just can't figure it out. We have been on the road for 42 days now. This is the first time this has happened.
  • Are there any lockout switches on the cargo doors that might cause that.I had an RV that had them on it. Try parking brake off and on a few times.
  • One thing to try is that if it's like our 03 Phaeton, the slides do not operate when the engine is running.
    On our previous coach, a 98 Fleetwood PA, there was a fuse in the battery compartment on the wall above the batteries that you had to push to reset if it tripped but I suspect yours is likely different than our PA.
  • My book doesn't show fuses for the slides. I don't know where to start checking
