RicoSuave
Aug 02, 2016Explorer II
Parking brake must be engaged for the jacks to operate. Given that, check for a switch near the brake that is activated when engaged. There may be 2 switches, one for the jacks and another for the dash light, etc. If only one switch then the jacks and the dash indicator share the same switch in which case you also may have no indication the brake is engaged. Quite possibly just a loose wire, connector, or switch on the brake pedal.
