Ava
Aug 02, 2016Explorer
If you have a hydraulic system, on my older power gear levellers there is a fuse inline from the 12 v source at the pump that feeds the hydraulic solenoids. The other colored wires going up to the control panel are just ground wires. As said above the ground is controlled by the park brake. If you are handy with a volt/ ohm meter, follow the wires and check for 12 v and grounds..
Good luck.
Good luck.
