simtec820
Aug 27, 2013Explorer
Help deciphering the monitor panel for battery readings
I'm checking again to see if someone can explain how to read the monitor panel.
With no power on to the RV at all, are the readings from the panel accurate because mine says LOW for Aux Batteries but they are fully charged (I think they are at least, cause I had them connected to power all night to get charged and they read 13.1 volts this morning)
If i engage the relay for the Aux batteries to load them, then the panel shows fully charged.
Why does the panel even show anything when the RV is powered off?
It also shows my Chassis battery at Half but the voltage on that battery is 12.1 on my meter. Turning on the relay also shows that battery at full charge afterwards.
Is it possible my two batteries are connected together through that Aux switch you use when you want to link them in for extra juice? (up in the cab to the left of the steering wheel, by the Emerg. Brake area?)
i have a 2006 fleetwood jamboree GT 31W
