Ivylog
Dec 20, 2014Explorer III
Congrats on picking a GREAT coach that you'll love. Start now giving your steering inputs a little longer to take affect as it's easy to want to oversteer something that long. With practice you will be impressed with how little steering wheel movement it takes to keep it between the lines.
Hopefully you know the code for the outside key pad as after opening the door with the keypad, press 9 to unlock the bay doors. If you do not have the code I would try pressing 9 when you unlock the front door with the remote... it might work. You can reprogram the key pad code but that will probably take a call to Monaco as I doubt my 04 instructions will work for your 08 system.
Hopefully the locks on the doors are not the common Ch751 key... you should have a key for the bay locks if all else fails.
38,763 PostsLatest Activity: Dec 05, 2025
