hotjag1's avatar
hotjag1
Explorer II
Mar 18, 2015
Help, no power to slideouts.
The last time that I used the slideouts, I had to flip the 12v disconnect rocker switch on the panel just inside the doorway to get them to work. I thought maybe I had bumped the switch prior to that and maybe it was in the disconnect position and had to be reset.
This time, I have flipped the disconnect switch numerous times and still have no power to the slides. I know that the switch is in the on position because everything else that is 12v works.
I have tested and verified 12v power at the fuse panel labeled slideouts.
Could there possibly be more than one fuse panel for the slides? Anyone else have this happen to them? All suggestions are welcome.
Thanks...Don
